Home > Technical (L405) > Stuck /Looping messages on instrument panel
Swasher
United Kingdom 2017 Range Rover Vogue SE SDV8 Corris Grey
Yes, I'm a newbie...
Got in car and was fiddling around with car ignition on (Engine off), looking into storing Favourite Satnav destinations, Apple carPlay etc..
Switched on engine as I was on the touchscreen for a while.. Everything working fine.
Thought I'd check service intervals, and oil level...
Switched off engine after a short while, switched ignition back on, had the standard 'TPM set to light load..Press OK to cancel' message. Pressed ok, message changes to 'Press Brake pedal and start button to start engine..Press OK to cancel', so I pressed OK
Message then just looped between the two above, and I couldn't get out of it apart from switching car off...
Has anybody else had this..?
Ears always open MY17 VSE FF Corris
Post #632291 19th May 2022 11:40pm
