![]() | Home > Technical (L322) > 2012 TDV8 Vogue, front (?) suspension issue |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 799 ![]() ![]() ![]() |
Had this scenario a few times with my old TDV8 Vogue (08MY). Ride height sensors would be my first port of call as this was the issue I had (three times across 160k miles). The older I get, the more I realise that people confuse wrinkles for wisdom |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
when I got my 2012 it had an apparent starter motor issue, whilst fiddling about with connections, I might have knocked the height sensor and bent the arm, the wrong way. needless to say, it was sinking overnight, at the front. but drove ok. after reading on here about height sensors, I had another look, and noticed it. unclipped it, and restored position and reclipped, -fixed! no more sinking. |
grayst01 Member Since: 08 May 2022 Location: Glasgow Posts: 105 ![]() ![]() ![]() |
thanks Chaps, I’ve ordered up 2 height sensors to at least have them to hand for the weekend! |
tj196443 Member Since: 08 Oct 2018 Location: Newcastle Posts: 186 ![]() ![]() ![]() |
I’ve been experiencing a similar issue and took the car to a local garage today, before I dropped it off I noticed the front offside air spring was hissing like mad and obviously leaking. The garage has just rang and quoted £550 to replace just the air bag. Is this a bit excessive ?? Thought a air bag would be about £200 with a mark up and perhaps an hours labour at the most ! |
TJ, having just bought 2 front bags from Island4x4 for £125ea +VAT I can say its seems bit excessive esp just for bags! Cheers, Steven.
I thought as much, I think the receptionist may have quotes for 2 air bags or an airbag and strut assembly, I will probably ring them in the morning when they open just to confirm they’ve got the pricing right. I Know they will want a diagnostic charge of roughly £60 but still seems really excessive to me. I’m tempted to just buy the part myself and fit it although I’m always pushed for time and would struggle to fit it in. I wonder what people have been charged on average for the fitting of 1 front airbag. |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1406 ![]() ![]() |
I tried to do mine myself, thought its only 6 bolts to get the strut out, after 4 hrs I had to give up on the lower bolt in the knuckle, put it back together and took it to a garage, they had trouble with it as well and it took a while to remove, seized in there solid as a solid thing, quite common apparently...
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7995 ![]() ![]() ![]() |
I’ve bought my own parts a few times and paid the garage to fit.
My local indi is now refusing to fit parts brought in with a car, as they have had too many instances of the wrong parts being supplied. The older I get, the more I realise that people confuse wrinkles for wisdom |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 784 ![]() ![]() |
"perhaps an hours labour at the most !"
Thanks for the replies, will probably take the hit this time and shop around next time. |
TJ, worth a try surely asking your local garage if they’d accept the parts to fit first?? If not, no worse off.
