![]() | Home > Technical (L322) > Front Windscreen Wipers / Mechanism |
| Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601
any one got any info on this?
| RJH Member Since: 22 Mar 2015 Location: Coventy Posts: 398
This shows how to access, had a similar issue previously.
Thanks for that very useful now my next request!!
I don't think they're available separately.
| 322BLL Member Since: 18 Apr 2019 Location: Estonia Posts: 73
They are not sold individually. Motor together with linkage.
Nice one will have a gander. failing that may add a wee bolt and washers through the middle 2012 Vogue 4.4 TDV8 - Current
Found this https://www.ebay.co.uk/itm/143538883971 just waiting for seller to confirm as description says Yes but compatibility check says NO.
So while waiting on the new poly bushes from the above link i had to re-attach, the drill bit then broke while trying to drill the centre out |
| Cymro in Slovakia Member Since: 19 May 2021 Location: Zdiar Posts: 8
Interesting point on the grips. I have this problem with it popping out at inopportune moments, like in the middle of a cloudburst just now! Had clicked it by hand a couple of times, but no joy, so had a go with grips. No luck, exactly the same result. So while awaiting the new bearing cups, tried to fill out the existing a bit. 8 layers of clingfilm and I can’t pull it apart ( not tried too hard!) So we’ll see might have to try the drilling out if it doesn’t hold. |
since i popped mine in it has held |
