Home > Maintenance & Mods (L322) > Sunroof does not open
nemmi69
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Barolo Black
so, got the top consol off (managed to crack it 😢 ). there is a black cover over the gear (see photo). The gear doesnt look it but can be turned with a hex bit. Wound it all thw ay open and closed and checked, no rust and plenty of grease.
So now, if i press fo
ward i hear a click. Backwards nothing.
Any ideas?
 What doesn't kill you is just bidding it's time.
Post #633732 5th Jun 2022 2:34pm
kevinp
Have you tried pressing the switch upwards, as in towards the sky to see if it tilts?
Post #633733 5th Jun 2022 3:06pm
nemmi69
Try up for 20secs, forward for 20secs What doesn't kill you is just bidding it's time.
Post #633735 5th Jun 2022 3:15pm
mjdronfield
Yes, holding the switch either upwards or forwards about 20 seconds should make the motor recalibrate the end stops next time it’s used. If not, you have a bit more investigation to do…..
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #633741 5th Jun 2022 4:20pm
You could check 3 fuses,
Fuse 58 20A, Fuse 41 5A and Fuse 53 30A.
Post #633742 5th Jun 2022 4:20pm
nemmi69
Fuses all OK What doesn't kill you is just bidding it's time.
Post #633744 5th Jun 2022 4:37pm
