![]() | Home > Technical (L322) > Hesitation, Red Restricted Perf, hardly runs, codes…4.4 TD |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3233 ![]() ![]() ![]() |
do a search on here for DPF. there's loads of info. it is unlikely your DPF is full or needs cleaning or removing. It may be sooted up by an air leak. In. my case it was the inlet manifold cracking, although most other's fault was caused by leaking pipes to the plenum.
Avityesboy Member Since: 27 Apr 2022 Location: Kidderminster Posts: 24 ![]() ![]() |
Hi, trouble is it won’t run now for more than a couple of seconds and most of these diagnostics require it to at least run…hmmm |
But I will check the manifolds as that’s free and easy as a first step I guess.. |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2715 ![]() ![]() |
Check for leaks in the form of oily residue from the 4 connecting hoses between the air inlet manifold and the inlet manifolds. |
Quick update, had a look as much as I could see at the manifolds and hoses and they are all fine…
As mentioned above, a high pressure smoke test needs to be done, it'll either rule out a charge air leak or confirm it. Just because there are no witness marks doesn't mean you don't have a leak that's has only just started. The DPF full DTC can be set when there is a lack of boost pressure compared to exhaust pressure (excessive back pressure), unfortunately, the ECM can't tell which of the sensor readings is correct so sets a 'protect the environment' DTC. |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
you can ignore the P040D code this will not be related. you need to get a tool to measure how much soot is in the DPF. as mentioned you need to find the cause for the DPF to fill up. if you have a IID tool also look to see when the last re-gen happened or the last attempt.
How is the smoke test carried out? Is that something I can do myself? Or do I need to get someone in to do it as the car won’t run? Thanks. |
I’ll have to see if my mates Snap on solus will read that, I know it could at least do isolated component tests too… |
A decent smoke tester will cost ~£300, find someone mobile that can do a 'high pressure' smoke test - high is not 100psi, more like 20-30psi, much more and you'll/they'll be damaging stuff.
I think what I’m going to do is get her recovered to my local specialist (Mark Smith) in Bicester for them to take a look at and diagnose. Thanks for your help so far I’ll keep you updated. |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4340 ![]() ![]() ![]() |
You've chosen the best route. If you're not au fait with these things best take it to someone who knows their |
That’s not me no but I’ve commented on his post and that’s what reminded me of Mark smith lol, I wish mine still drove and was an amber warning lol |
Taken to Mark Smiths specialist for diagnosis.
