![]() | Home > Technical (L322) > Bad starter TDV8 3.6 ?? |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8781 ![]() ![]() ![]() |
Hi, No point guessing with a fault like that could be all sorts...
Deputy Member Since: 23 Nov 2021 Location: Maidenhead Posts: 33 ![]() ![]() ![]() |
I tried to start with a booster pack but it doesn’t even attempt to power the starter motor.
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 700 ![]() ![]() ![]() |
To be fair, it could be a host of things. But I think I’ve read before the ignition switch can play silly beggars on these and also the starter relay. Going from experience, my starter ‘clicked’ twice before she started, that was enough for me to get the starter changed. If you have no click, and the lights don’t dim when you try and start, to me, that’s not a starter motor issue…….but I could be wrong & probably am!😂😂 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Nothing in life, or fatty ownership, is certain.... |
I’m thinking …..bad relay
Update …
That would point towards the solenoid that controls the starter motor (the lump on the side of it)
Thanks Pete,
New Denso starter fitted.
