Home > For Sale & Wanted > [For Sale] various items For L322
Classic888
Following the sale of my FFRR I have the items listed below to dispose of. Prices do not include postage, I thought this was the best way to go, so if multiple items were to be purchased combined postage could be applied. Where it states X 2 etc this is the quantity you will get for the listed price. If it says 4 available etc the price is per item. Priced in UK Sterling. Apologies for the messy listing my skills need addressing!!
RLB000011 BEARING + CIRCLIP LR 25.00
LR031439 OIL FILTER LR 12.00
DQG000023 BRACKET LR 5.00
TVB500400 BEARING TRANSPART 18.00
4744015 IGNITION COIL FoMoCo 25.00
SOE500030 WEAR SENSOR LR 15.00
SEM500050 WEAR SENSOR LR 15.00
SEM500026 WEAR SENSOR LR 15.00
SEM000012 WEAR SENSOR LR 15.00
SSF500011 ABS SENSOR LR 40.00
SEM500050 WEAR SENSOR ?? 5.00
KHC000030 BUSH FEBEST 30.00
RGD500131 STABILISER X 2 MOOG 18.00
QJB500050 TIE ROD END X 2 TEILEX 18.00
KHC000040 BUSH LR 20.00
RGX000080 BUSH 4 available LR 20.00
RYP100161 BOLT LR 3.00
QFK500030 INNER TIE ROD X 2 ?? 10.00
LR030048 DROP LINK X 2 FEBEST 12.00
TZB500100 OIL SEAL LR 5.00
LR007769 OIL SEAL 2 available LR 5.00
RYP501160 BOLT 2 available ?? 5.00
RYP000061 BOLT 4 available LR 4.00
RGI000012 WASHER 2 available LR 3.00
QYH100271 NUT 4 available LR 1.00
RYH501100 NUT 4 available ?? 0.50
RYH501100 NUT 7 available LR 1.00
RKB5000151 REAR AIR BAG 2 available CHINESE 50.00
EATON M112 SNOUT BEARINGS FAG 15.00
EYC000120 CLIP X 5 3 available LR 3.00
EYE000041 CLIP X 6 LR 6.00
DKI000010 CLIP X 2 LR 1.00
SDG100000L SCREW X 2 LR 1.00
TZZ500020 DIFF BEARING X 2 LR 10.00
EYC500300 CLIP X 3 LR 1.00
TYX000100 O RING LR 1.00
JYP000040 BOLT LR 1.00
PYQ000020 PIN X 5 LR 3.00
RYC500220 CLIP X 2 LR 2.00
CDU3506L CLIP LR 1.00
SGK000080 CLIP LR 1.00
XKB000022 SWITCH LR 8.00
4603183 SENDER BP 8.00
EYC000340 CLIP X 8 ?? 5.00
KKN500051 FIXING X 2 LR 5.00
KKN500061 FIXING X 2 LR 5.00
RGX000071 BUSH 2 available ?? 15.00
RGX000060 BUSH 2 available ?? 10.00
TAG500122 FRONT DIFF 3.73 USED LR 50.00
XRA500031 TMC MODULE - USED LR 5.00
YIW500200 NAV DVD DISK - USED LR 25.00
Post #634393 12th Jun 2022 10:29am
Classic888
BUMP.
Any takers at £350 for everything including delivery to UK mainland?
Post #646183 22nd Oct 2022 8:42am
