Home > Technical (L322) > Restricted performance on deceleration - P0107
Warminster 201289
Hi all,
After resolving a previous issue with 2 new turbos, I again have restricted performance.
This happens on deceleration, not whilst accelerating and triggers the fault code P0107- no other codes appear.
I have checked and replaced the map sensor just once and it seems to be functioning as required.
Checking live data I get 1.3v at idle and 100kPa. It increases with acceleration and I issue up to the limiter.
When decelerating the volts drops to 0.25 and the pressure accordingly.
I do not know what may be causing this. Has anyone had any experience or know where to trouble shoot?
Thanks in advance
Post #634622 14th Jun 2022 6:08pm
Phoenix
What supply voltage are you getting at the MAP sensor? - measure at the sensor wiring across the +ve & -ve, should be in the range of 4.75 - 5.25VDC
Post #634625 14th Jun 2022 6:34pm
Warminster 201289
Just tested and measuring 4.9v at supply and have continuity at ground.
Post #634629 14th Jun 2022 7:18pm
Phoenix
Is this a 3.6 or a 4.4 TDV8?
Post #634633 14th Jun 2022 7:48pm
Warminster 201289
Sorry, it’s the 4.4TDV8.
Post #634634 14th Jun 2022 7:50pm
Phoenix
Assuming no intake leaks, blocked air filters, charge air leaks etc. I'd be looking for delaminating hoses creating a restriction on deceleration. As always, a smoke test would be the preferred first step but obviously not everyone can do that.
It would also be worth checking the MAF for contamination or leaks, the correlation between the two readings has to be within a fairly tight envelope.
I've seen a partially oil filled intercooler give similar errors, not on a LR though.
Post #634637 14th Jun 2022 8:13pm
Warminster 201289
No obvious leaks and I’ve replaced the filters (hoping this was the reason) but not thought about delam pipes!
I have spoken to my friendly garage but they can’t lookalike it for a week and I don’t have smoke test equipment.
I visually checked the MAF and looked ok, but not used leaks.
I’ll focus my effort on looking for a delam.
Thanks for your help!
Post #634640 14th Jun 2022 8:24pm
Phoenix
They usually occur on bends rather than straight-ish sections, look for discolouration on the outside where oil is penetrating and feel for any weaker areas when poked and prodded, an endoscope is invaluable for looking inside for bubbles and tears and can be found quite cheaply on fleabay to connect to your phone or PC. - it will be something simple that's causing it, finding it is the hard part, good luck!
Post #634641 14th Jun 2022 8:53pm
Dolphinboy
take it down to Steve at T and S Norman in Shepton mallet. What he don't know about the L322 doesn't need knowing. He fixed my RP prob by engineering nouse, after all the LR dealers and specialists failed. pm me for details if you can't find them on t'internet
Post #634644 14th Jun 2022 9:48pm
