![]() | Home > Technical (L322) > Help me with my vibrations! |
Caesium Member Since: 21 Sep 2021 Location: Essex Posts: 454 ![]() ![]() ![]() |
The sliders are not really the problem on the rear callipers. It's the piston that gets seized.
MartinD Member Since: 20 Oct 2010 Location: Edinburgh Posts: 303 ![]() ![]() ![]() |
Yeah I've checked them and they're nowhere near as hot as it was - both the rears are now the same 'warm' temperature. 2011 4.4 TDV8 Vogue SE - 'Black Betty'
batfink Member Since: 20 Jun 2011 Location: Milton Keynes Posts: 209 ![]() ![]() |
Have you had the wheels checked in case one of them is slightly buckled ? |
Well, yes and no. They've been balanced and the tyres changed twice now and noone has said there's a problem.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822 ![]() ![]() ![]() |
I take it you have had all the suspension arms and bushes checked, the alignment will not necessarily pick this up if you have issues.. Pete
It has been at the specialist 3 or 4 times over the past month for various work and every time the vibration has been talked about.
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3385 ![]() ![]() ![]() |
This must be very frustrating to say the least. I can only offer a few suggestions;
JayGee - I believe that has all been done by the specialist as he was aware of the issue every time I went in. He stated he couldn't find any issues that would cause the vibration.
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1880 ![]() ![]() |
Swap wheels front to back, see if it moves to the steering axle
Thanks Mikey - was hoping you'd pop up! 2011 4.4 TDV8 Vogue SE - 'Black Betty'
Get the wheels on a hunter road force machine as this tests for out of round issues 2012 TDV8 Vogue (L322) |
No idea where I'd find one of them round here! 2011 4.4 TDV8 Vogue SE - 'Black Betty'
Pro-Grip in Falkirk have Hunter wheel alignment so they might have a hunter wheel balancer.
Ever used them?
