Home > Maintenance & Mods (L322) > NSF upper suspension arm 'distortion' |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7905 |
Weird, doesn't look that old either....
21st Jun 2022 9:33pm |
Cheers, it's possibly deceptive as I replaced the bush, it was clear when trying to refit it that there was something fundamentally wrong with the arm - well, as far as it being used on an L322...
21st Jun 2022 9:46pm |
Won't be long, it'll get there... Pete
21st Jun 2022 10:55pm |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2299 |
The curve in the used one appears to be tighter which may have occurred from a big impact by the wheel on something. |
21st Jun 2022 11:23pm |
Which is what I was initially thinking - the original wheels & tyres showed no signs of an impact with enough energy to do that, there are no other signs either. Other than the camber being off, the toe was pretty good before I started with the bush & ball joint replacement - which I initially put down to wear, once I'd changed the upper arm, the camber was better but the toe was way out on that side, which made me think it'd been replaced at some point and the alignment corrected to suit.
22nd Jun 2022 7:06am |
Yep, although I'd only get bored if there was nothing to keep tinkering with... |
22nd Jun 2022 7:09am |
Don't say things like that..... Pete
22nd Jun 2022 9:22am |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 775 |
I would be interested to see the old one against a BMW X5 E53, very similar..
22nd Jun 2022 10:06am |
There's a few differences in the casting but the angles and compound radii do look very similar - the old one has been consigned to the scrap metal skip now, never to trouble me again! |
22nd Jun 2022 2:36pm |
