![]() | Home > Off Topic - Other Cars > Best brake bleeding kits |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1332 ![]() ![]() ![]() |
My daughter bought me the VS820 and it is very well made. I bled my brakes with it and it got quite a few air bubbles out the system and the pedal felt a bit firmer.
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1238 ![]() ![]() ![]() |
I have the Gunson Eezibleed tool, widely available, from £20 to £25, £20 at Halfords recently. Easy to use, has been reliable and a Rimmer Brothers video ( Amongst others ) showing how to use it. Uses spare tyre air pressure, bit of a pain, but I do not have an air compressor. |
Thanks for the replies |
m@ttsFF Member Since: 12 Dec 2017 Location: Surrey Posts: 336 ![]() ![]() ![]() |
If you have a compressor Sealey also have a vacuum bleeder which works well .
Bought this Clarke CHT 857 brake and clutch bleeding kit. £63 from Machine Mart. Gets good reviews and feels good quality.
Used the above mentioned Clarke bleeding kit on a non Range Rover yesterday - a car fitted with performance brakes and two bleed nipples per brake. The Clarke device is a brilliant piece of kit. Never having bled any brakes before, it couldn’t have been simpler to use and is a very sturdy and well made piece of kit. It took about 30-40 minutes before the pressure guage showed any signs of losing pressure and even then, only the slightest reduction which was easily dealt with by gently pumping the device a couple of times. Highly recommended for occasional use DIYers @ £63 👍🏻 |
