Home > Technical (L322) > Cameras - Missing Calibration
RR2B
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Baltic Blue
All the surround cameras are working perfectly, but I have had the below fault codes which will not clear since purchasing the car over a year ago.Is calibration possible with the IID Tool? If so, where do I find the relevant menu?
The only reason i want to clear the codes is for the childish joy of seeing zero faults on the code reader, however short-lived that may be!
Thanks in advance for any pointers.
IPMB-Camera
B12BD-54 (2F) Rear camera - System programming failure - missing calibration
( on 26-06-2022 17:50:04 at 134780 mi )
B12BE-54 (2F) Front left camera - System programming failure - missing calibration
B12BF-54 (2F) Front right camera - System programming failure - missing calibration
B12C0-54 (2F) Left mirror camera - System programming failure - missing calibration
B12C1-54 (2F) Right mirror camera - System programming failure - missing calibration
( on 26-06-2022 17:50:04 at 134780 mi ) 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #635522 26th Jun 2022 6:45pm
RR2B
Bump - anyone else had this issue? 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #652840 7th Jan 2023 11:46am
cass
If everything is working I'd be tempted to leave it alone, trying to achieve a JLR product showing no faults is a bit of a tall order, JLR struggle to manage this with brand new cars so I don't fancy your chances with yours at 10+ years old.
If you really must find something to fill your time in I would suggest starting with something relatively simple like reversing climate change and persuade Mr Putin to leave the Ukrainians alone then progress to the challenges of sorting your car.
Post #652881 7th Jan 2023 5:25pm
Ansi
Switzerland 2010 Range Rover Autobiography 5.0 SC V8 Adriatic Blue
After changing the surround camera module, I have the same faults, no idea how to fix this.
I assume that the same module was changed by the pre-owner of your fatty.
Post #652935 8th Jan 2023 8:55am
