Home > Maintenance & Mods (L405) > Creack/Crack when turning steering wheel
MonkeyMan
Hi Folks,
My otherwise well behaved 2013 AB has developed a nasty continuous habit for the last 3 months of making a loud creak or crack sound when I turn the wheel at low and medium speeds. I guess its not as obvious at high speeds as the amount to turn then is much smaller. Its a sharp sound, but not grating or grinding.
Any suggestions before I trundle off down to the garage with it? I am in no way technically minded, so any advice that has words like 'track rod ends' in it may as well be in Swahili unless I can convince some of my more mechanically gifted friends to investigate your advice in return for fermented beverages.
Thanks in Advance!
Post #635845 1st Jul 2022 5:50pm
Kelele hiyo inaweza kuwa kitangulizi cha kushindwa kwa kifundo cha mguu ambapo gurudumu linakaribia kudondoka, ikiwa huna uhakika labda ni bora kuivutwa huko... Hapo tena kunaweza kuwa mwisho wa fimbo... Pete
-Click here for Thread-
Post #635856 1st Jul 2022 6:43pm
MonkeyMan
asante sana, nitaipeleka kwenye karakana mara moja
Post #635865 1st Jul 2022 7:39pm
bebechoon
France
You are all a load of silly billies on 'ere, innit
 It's "bébéchoon", ackcherly, with accents. 'Steve' to my chums.
20 years ownership of Solihull products, ALL GONE NOW, sniff!
Current motor: Suzuki S-Cross 4WD auto, 1.4 petrol. Oh so reliable! 8 years now and no problems. Oh, all right then, a leaking shocker replaced under guarantee.
Previous:
TD6 HSE L322 Auto FF
2.5 TDi 4-door Classic
Disco II
And my 1st Rangie: in 1995, a 2-door VM 2.5 diesel Classic
Not to mention the Lada Niva before those. (I said not to mention it!)
Post #635866 1st Jul 2022 8:01pm
MonkeyMan
Sorry, do you not all speak Swahili?
Haylands said it could be the wheel joint failing (I'm outside that Vin range, thankfully) or a track rod end.
Post #635867 1st Jul 2022 8:08pm
mpirie
My 2013 AB has developed the same issue.
It sounds like you need TSB LTB000906, where they replace the oil in the transfer box.
Mine goes in next Wednesday to the dealer. Big Cry
Mike
Post #635868 1st Jul 2022 8:10pm
bebechoon
France
Je, unazungumza Kiswahili kwa Ascot, basi?
Previous:
Disco II
Post #635870 1st Jul 2022 8:13pm
