Home > Maintenance & Mods (L322) > Part identification- EGR Cooler i believe
Snowy90 L322
United Kingdom 2019 Range Rover Vogue SDV6 Baltic Blue
Can anyone tell me what this is?
I am trying to trace a leak of what looks like Power Steering fluid or ATF fluid. the underside of this rectangle gold colour object is very wet and dripping down onto the fan pulleys and below. Not a huge deluge but a consistant drip i would say.
Any ID welcome and also what could be causing the leak would be incredible.
Apologies
in advance for not responding to any queries imediately Kids and Scouts duities calling tonight, but i wanted to get it out there so i could investigate properly tomorrow.
Post #636182 6th Jul 2022 5:45pm
Snowy90 L322
Just incase 54 plate 3.0 TD6 155,000k
Post #636183 6th Jul 2022 5:46pm
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
I think, forgive me because I have a v8 petrol, that it’s the EGR cooler.
Regards ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #636186 6th Jul 2022 6:06pm
RRPhil
Microcat identifies it as the EGR cooler, as Simon stated above.
If you Google the Land Rover part number WIA000040 you'll be able to find the equivalent BMW part number.
Phil
Post #636189 6th Jul 2022 6:54pm
Snowy90 L322
Gents, thats helpful, thanks.
SO trying to track down this leak what is it cooled with, the substance is like i can only describe as a thin oil like ATF/pWS fluid
If the EGR cooler isnt liquid cooled then i am barking up the wrong tree!
Post #636226 7th Jul 2022 9:35am
UK Marine
It’s definitely cooled with liquid. Maybe your transmission cooler is passing some transmission fluid into the cooling loop.
Simon
Post #636229 7th Jul 2022 9:46am
Snowy90 L322
Ok so that kinda narrows it down a bit, i am losing coolant somewhere.
That doesnt sound good coolant in the transmission!
Post #636230 7th Jul 2022 9:53am
Snowy90 L322
Are there any usual suspects fpr leaks around the cooler
So is it possible to do an EGR delete and bypass the cooler?
Cheaper than replacing the cooler i am guessing.
Post #636658 11th Jul 2022 3:05pm
