![]() | Home > Technical (L322) > Replacing bluetooth module |
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1055 ![]() ![]() |
Just tried to replace my bluetooth module, but couldn't get it out! Probably because it was getting dark, but I'm assuming the torx screw that holds it in is in the middle of the unit, and is therefore very limited access with everything in situe? Is this correct? Do you need to undo the nuts which hold the bracket onto the chassis to get better access?
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1528 ![]() ![]() |
As above: Halfrauds ratchet spanners come with a hex screwdriver bit adapter which makes it easy. I've also got some other tool sets from snap-on.
BrianC Member Since: 15 Apr 2009 Location: central belt Posts: 1429 ![]() ![]() |
take the 2 m6 nuts off the bracket at the top that holds the full bracket and it will take you 2 seconds to then get the torx screw out. |
You were right Big! Still a bit fiddly, but got there in the end! Anybody know why only a limited number of contacts appear to be synchronising? Also what other new functionalitiy comes with the new software? 2012 SDV8 Vogue SE |
