Home > Technical (L322) > 4.4 TDV8 NON START, FUEL PRESSURES.
daveturbo
IM HAVING PROBELMS AGAIN WITH MY 2011 TDV8, WAS RESTRICTED PERFORMACE NOW NON START. THE WIRING PLUG HAD CORROSION DUE TO A VERY SMALL WATER LEAK FROM ABOVE ON IT IT,CHANGED THE PLUG STILL NO START,SO HAVE A NEW SENSOR TO TRY TONIGHT. GOT 0.8 VOLTS FROM SENSOR NOT SURE IF THIS IS ENOUGH SOUNDS LOW TO ME. GOT P0088 FUEL RAIL PRESSURE TO HIGH AND P0192 FUEL RAIL PRESSURE SENSOR LOW VOLTAGE.
GOT A FUEL RAIL READING OF 4900 PSI OR 344 BAR, ANY HELP PLEASE. Mercedes AMG w207
E class Cabriolet
Overfinch L322 4.4 tdv8
1987 sierra rs cosworth 3 door white.
1985 escort rs turbo series one.
1992 sierra sapphire 4x4 cosworth red
1993 sierra sapphire cosworth 4x4 silver
1993 sierra sapphire cosworth 4x4 white
1995 ducati 916sp.
Post #636644 11th Jul 2022 11:47am
GraemeS
Australia
Have you considered installing the sensor wiring repair kit LR108438, as referenced in LTB01083?
Post #636645 11th Jul 2022 12:14pm
daveturbo
4.4 TDV8
I was not aware is a wiring kit, so going to order one now ,fingers crossed. Mercedes AMG w207
E class Cabriolet
1995 ducati 916sp.
Post #636647 11th Jul 2022 12:45pm
GraemeS
Australia
3 crimp joiners are normally used but you might organise your own joiners especially if you don't have the crimp pliers.
Post #636653 11th Jul 2022 1:11pm
daveturbo
4.4 tdv8 non runner
WELL FITTED THE WRING MOD AND WAS RUNNING GREAT UNTIL THE ALTERNATOR HAS NOW PACKED IN DOH, THINK IT MIGHT BE UP FOR SALE SOON LOL. Mercedes AMG w207
E class Cabriolet
1995 ducati 916sp.
Post #636701 12th Jul 2022 9:28am
GraemeS
Australia
The alternators that LR fit don't last nearly as long as an alternator should and shouldn't be taken as an indication of the state of life for everything else on the vehicle. I had to replace mine's alternator at 150K kms which is typical but still poor life for an alternator.
Post #636706 12th Jul 2022 10:46am
daveturbo
4.4 Alternator
Did you remove it from the top or bottom ,and is it a pig of a job Buddy. Sorting mine on monday. Mercedes AMG w207
E class Cabriolet
1995 ducati 916sp.
Post #636870 14th Jul 2022 11:51am
GraemeS
Australia
I removed the alternator from the top, after removing the fan shield c/w fan (LH thread - light tap) and belts. Don't split the a/c pipe as it can be moved out of the way. The lower bolts in the fan shield were awkward because I didn't have a suitable ratchet and the ramps weren't high enough to allow adequate room for my arms to move. I've since purchased a 1/4" battery-operated ratchet although a 1/4" air ratchet would be smaller.
I replaced the 2 belts, idler pulleys, belt tensioner and the water pump to ensure that they would last at least another 150k kms. The stretch belt was clamped to the crankshaft pulley then the crank rotated.
I spread the work over 2 days - removed on the 1st then refitted on the 2nd as I had the time.
Post #636873 14th Jul 2022 12:35pm
daveturbo
4.4 Alternator
That's great help , thank you Buddy. Mercedes AMG w207
E class Cabriolet
1995 ducati 916sp.
Post #636881 14th Jul 2022 3:23pm
