Home > Maintenance & Mods (L322) > Rear screen washer pipe size
Baltic Blue
My rear screen washer has blocked again for the umpteenth time.
Luckily it was working fine for the MOT two weeks ago, but sadly not today.
I replaced the one way valve a couple of years ago with one from some plant irrigation bits I had, but can’t remember the plastic pipe bore size ??
Does 1.6mm sound right ??
Next size I can see is 3mm .
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #636661 11th Jul 2022 4:05pm
Range Rover L322
<deleted>
Post #636683 11th Jul 2022 9:20pm
Phoenix
I'd be looking at why it's blocked - typically it's due to biological matter in the washer bottle (leaf litter etc.) festering and blooming in the pipes. Screenwash won't clear it but a dose of bathroom mould cleaner will break it up, you just need to flush the screenwash reservoir & pipes to clear it out - bearing in mind that the pipes need the cleaner to be in them for some time for it to work.
The problem is caused by the rear screenwash pipes being in the 'warm, but not hot enough to kill the bacteria' cabin on their way to the rear tailgate, whereas the front screenwash picks up heat from the engine bay which is well over the 56 deg. C. required to kill off bacteria.
Post #636689 11th Jul 2022 10:02pm
Merchy
This got me thinking about my last MOT, I watched the whole thing and chatted to him as he had never MOT'D a range rover!! He never checked the rear screen wash but the guy was very thorough so I would agree with the comment from RangeRoverL322.
I know this does not answer the pipe size question but may help people with the MOT aspect.
Post #636696 12th Jul 2022 7:49am
Baltic Blue
I’m no expert, but believe that any feature fitted as standard , such as rear screen wiper, washer, headlamp washers etc. can be given as an advisory or Fail, depending on issue, if they don’t work correctly.
I will be stripping down to investigate my rear washer and tube size later this week.
Post #636704 12th Jul 2022 10:36am
Baltic Blue
I have been ringing around to get a new non return valve,
Would you believe JLR only sell the complete pipe , pump to wiper motor with the valve, £36 sir !!!
The 50p option from a garden centre has lasted 2/3 years, just wish I had bought a spare Rolling with laughter
Post #636709 12th Jul 2022 12:42pm
Superspoons
England 2006 Range Rover Vogue SE 4.2 SC V8 Zambezi Silver
I've just had mine apart as no water was coming out - 1.6mm sounds right. Mine was jammed up at the two jets so cleaned it out with a safety pin and now ok.
Thinking of doing what this guy did.. but be prepared to fill up your washer reservoir frequently Laughing
https://www.youtube.com/watch?v=Utqnv_ApJrw Gavin
2005 Range Rover Vogue SE 4.2 Supercharged V8
Follow my 4.2 Supercharged antics -
https://www.fullfatrr.com/forum/topic63354.html
https://www.instagram.com/l322_supercharged/
https://www.youtube.com/channel/UC8ChHNSdscnJarKjBLd_IAg
https://www.youtube.com/@ChallengingClassics
Post #636711 12th Jul 2022 1:48pm
Baltic Blue
I have just cleared mine using hot water and a syringe.
The bore of the pipe is actually 4mm, for future reference.
Post #636716 12th Jul 2022 2:54pm
JayGee
Replaced my arm, one way valve and blade over the last few months to get a clean sweep without streaks. Still can't get the jets to put screenwash exactly where I'd like it but it's better than it was. 2012 TDV8 Vogue (L322)
Post #636719 12th Jul 2022 3:01pm
Baltic Blue
The beauty of using the syringe full of hot water to force water through the motor and jets , you can adjust the nozzle with a needle whilst squirting water through without the wiper keep moving.
Post #636720 12th Jul 2022 3:06pm
DanRRL322sc
Point of note Mike - some of the 911 models do come with a rear wiper, on some iterations you had to tick the delete option on the order to avoid it Very Happy
Post #636838 13th Jul 2022 6:51pm
