Home > Technical (L322) > Missing part ID
Slow progress
Missing part ID
Hi All,
I’ve checked the microcat and can’t locate the part on the diagrams and thus the part ID I need. I’m looking for a replacement 10mm bolt and washer that fixes the rear light clusters in place, I’ve been missing one set since I bought the vehicle.
Spoke with Robin at Duckworths and he has the same issue!
Many thanks for any help you can give,
David L322 TD6 2003
Epsom Green- the dogs car which has worked it’s way into being the family car 😮
Post #636938 15th Jul 2022 3:42pm
these rear lights can be easily stolen using a thin 10mm spanner....i would replace with an allen or hex bolt.. ... - .- -.
Post #636940 15th Jul 2022 4:02pm
Slow progress
Hi Stan,
I hadn’t realised that was a problem!
I’ll find 4 bolts, any idea if there’s a ready made set to purchase? L322 TD6 2003
Post #636949 15th Jul 2022 5:05pm
M6 16mm FLANGED BUTTON HEAD ALLEN BOLTS should do...
https://www.ebay.co.uk/itm/321232365051?va...xyffZSZDg4
(be careful as link defaults to M5...) Pete
-Click here for Thread-
Post #636953 15th Jul 2022 5:34pm
JCW
These are the genuine LR torx head bolts
https://rimmerbros.com/Item--i-FYP106392
Post #636955 15th Jul 2022 5:40pm
The eBay ones won't rust though... Whistle Pete
Post #636956 15th Jul 2022 5:42pm
garyRR
Boltbase, Kays and J Clarke Marine are all fine. I buy A2 and A4 stainless for boats from them and confirm they do not rust.
A2 grade should be fine for this location. 2015 Range Rover Autobiography 4.4 SDV8
Post #636982 15th Jul 2022 11:45pm
p38arover
Australia
I've had my rear lights off to run a cable. I can't recall anything special about the bolt that would preclude using any bog standard 10mm hex hear bolt (I presume it is an M6). Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #636985 16th Jul 2022 5:20am
aljo
United Kingdom 2019 Range Rover Vogue SE 2.0 PHEV Santorini Black
Try screwfix or toolstaion you may be pleasantly surprised 👍 Last night I lay in bed looking up at the stars in the sky and I thought to myself, where,s the f**king ceiling!!
Post #636999 16th Jul 2022 11:10am
