![]() | Home > Technical (L322) > Ignition Switch |
Jamesh7216 Member Since: 30 Dec 2021 Location: Baschurch Shropshire Posts: 46 ![]() ![]() ![]() |
I am having problems with the ignition switch on my 2006 TD6. The key turns without any problems but the ignition sometimes turns on but most times nothing happens. If I buy and fit a new ignition switch is there anything I need to be aware of like key coding etc? |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8816 ![]() ![]() ![]() |
You can change just the bottom part below the barrel, it doesn't need coding...
Yep, could be that, or the immobiliser or the steering column etc... that's why you need some codes read as it night point you towards the problem...
Another question, is the BMW X5 Ignition switch interchangeable with the L322, they seem a lot cheaper to buy |
