Home > Technical (L405) > 4.4 sdv8 2013 problems
E6DYO
United Kingdom 2014 Range Rover Vogue SE SDV8 Carpathian Grey
hello I went out to my range rover vogue l405 4.4 sdv8 today and tried to start it I noticed it turned over for a little longer than usual then started up.
I tried to drive it touched the accelerator pedal and it struggled to rev and then cut out.
push the button to start it and it turns over without starting then push the button again and it turns over a few turns then starts but same again touch the accelerator pedal and cuts out. says restricted performance.
I have fault codes
Post #637845 25th Jul 2022 10:19pm
MrWold
England 2014 Range Rover Autobiography SDV8 Barolo Black
"jeep" ? Chris
2014 FFRR 4.4 SDV8 Autobiography Barolo Black
2012 RRS SDV6 HSE Baltic Blue
and before I saw the light:
2011 Suzuki Grand Vitara SZ5
1998 Ford Mondeo V6 Ghia X
1990 Citroen BX GTi
1973 Triumph GT6
Post #637847 25th Jul 2022 10:27pm
E6DYO
changed it for you👍
Post #637848 25th Jul 2022 10:29pm
MrWold
That's better. Sorry I can't help though other than to say mine, with good service history and 114,000 miles, doesn't really turn over first, it just fires up. Chris
1990 Citroen BX GTi
1973 Triumph GT6
Post #637849 25th Jul 2022 10:40pm
E6DYO
thanks for your help 👍
Post #637850 25th Jul 2022 10:42pm
GraemeS
Australia
LTB01083 refers to an issue with the electrical connector in the link harness to the fuel pressure sensor. The fix is to replace the link harness and connectors with a new connector for the sensor.
Post #637859 25th Jul 2022 11:33pm
E6DYO
thank you will give that a look today
Post #637864 26th Jul 2022 8:17am
GraemeS
Australia
If the connector is the cause then Bosch connector 1928403966 has been suggested as the required part to fit the sensor.
Post #637873 26th Jul 2022 9:22am
mlambton
United Kingdom 2015 Range Rover Autobiography SDV8 Corris Grey
I had the same issue last week take a look at the link below. I suspect it will be the same issue. Its a relatively cheap fix too!
https://www.fullfatrr.com/forum/topic52494.html 2015 Range Rover L405 SDV8 AB Corris grey
2010 Range Rover TDV6 HSE Narra Bronze sold
2006 Discovery 3 SE green sold
Defender 90 td5 sold
Defender 90 soft top sold
Post #637948 27th Jul 2022 5:31pm
E6DYO
fixed turned out to be the sensor on top of the high pressure fuel pump caused by bad fuel
Post #638007 27th Jul 2022 11:25pm
