![]() | Home > Technical (L322) > recommendations for diagnostics tool |
razzer Member Since: 20 Feb 2015 Location: blackpool Posts: 54 ![]() ![]() ![]() |
good morning all. my 2003 L322 3.0d has flagged up a air suspension inactive fault. the LED on the height selector switch isn't lit. can anybody please advise as to a reasonably priced tool suitable to help me get the bottom of the problem. the suspension appears to be slightly raised equally on all four corners. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8815 ![]() ![]() ![]() |
https://www.fullfatrr.com/forum/topic64099.html
hi. thanks for that, didn't know they existed. |
TheRealScotty Member Since: 26 Nov 2017 Location: Luton Posts: 3 ![]() ![]() ![]() |
I have a 2003 TD6, because it's architecture is basically that of a BMW E53 X5 I just use the BMW INPA garage software I already had on an old laptop. I'm not sure what more an IID tool can do, if anything, but this will let you investigate fault codes, read live values, adjust settings like suspension height etc.
