Home > Technical (L322) > Light Burning Oil Smell from Front Offside when Towing ?
TeeMyob
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
Hi,
Recently been towing a 1500kg Hymer caravan . Sometimes, I get a light burning oil smell from the front end.
L322 2012 Westminster 64,000 miles Full LR service history bar one.
Should I worry?
Any thoughts please?
Post #638550 2nd Aug 2022 10:15pm
Phoenix
Personally, I'd worry that some tw@t had installed a towbar and hooked up a tin tent to the back of my car....
It may well be an oil cooler issue - are you having to top-up the coolant also?
Post #638552 2nd Aug 2022 10:25pm
TeeMyob
this tin hat bought a car for that purpose. We have a motorhome, so a real tin hat.
But the car came with a factory tow bar, that sshy I bought it.
Our grandchildren holiday a lot with us in our tin hat, caravan, motorhome and Villa in Spain. So lots of choice.
Post #638554 2nd Aug 2022 10:42pm
DrRob
Check for the known oil cooler leak issue....lots on here. Leaks into the V and down back of engine.
If bad, there will be oil on rear of the engine undertray around the circular crossmember and also in the coolant header tank. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #638561 3rd Aug 2022 7:19am
TeeMyob
Yes Dr. ROB
Seems it is the oil cooler and I have been quoted £1000 to replace it.
Post #677551 8th Nov 2023 7:51pm
Fox889
It’s either had an oil cooler before & it’s simply the oil residue burning off when the engine gets hot or the oil cooler is on the way out & leaking oil. Mine went at 86k, pulled into a petrol station & saw smoke whisping from the bonnet!
Very common issue on these girls, 4.5hrs of labour plus the part. Nissen do a replacement which is about £100 cheaper than a genuine LR, for the sake of £100 I went for the LR one. Think my bill from an Indy was circa £750 but that was 3 years ago.
You’ll find plenty on here about the oil cooler, some say just replace the gaskets (I didn’t) some say replace the whole unit, which I did. The old saying, you pays the money etc etc.
If you’re good with the spanner’s it’s a diy job and the site sponsors will give you a good price.
Hope this helps & good luck. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
1973 Honda CB250 K4
Post #677591 9th Nov 2023 10:02am
TeeMyob
thanks for the info
Post #677624 9th Nov 2023 8:09pm
