![]() | Home > Maintenance & Mods (L322) > Tracking for the L322 2010-2012 TDV8 |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3246 ![]() ![]() ![]() |
Where are you in somerset? I used these guys. very switched on owner from Hungary or Poland. did Aircon too.
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 778 ![]() ![]() |
Not sure if they still do it but Kwik Fit did a deal where you got 2 years of checks and adjustments for just over £100.
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1486 ![]() ![]() |
I can also vouch for KwikFit doing a proper 4 wheel alignment. 2015 Range Rover Autobiography 4.4 SDV8 |
Some may do, some may add bits of cardboard under the wheel pods to get the alignment in spec.
Nylands Member Since: 08 Sep 2019 Location: Somerset Posts: 200 ![]() ![]() ![]() |
Thanks everyone
(All KwikFit garages use Hunter) 2015 Range Rover Autobiography 4.4 SDV8 |
Thanks Garry, I'll talk to them re the car set up. |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3304 ![]() ![]() ![]() |
Hunter is the best but also be aware that adjuster bolts may be seized and the garage may decline to adjust for fear of destroying the nuts and bolts so I'd make sure they are all freed up before booking it in. 2012 TDV8 Vogue (L322) |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3313 ![]() ![]() ![]() |
Check with your local Kwik Fit as there are still a few scattered across the country that haven't been updated yet.
I had one seized so they just did the best they could to get it to within parameters. |
I would give the boys I linked to a call. Very knowledgable and does a lot of 4x4's. I was really happy with the service (took them over an hour) and the boss is on site so happy to chat to you ref anything. |
When I had an alignment check the conversation went quickly from we 'need' to align the rears to 'it will be OK as it is' when they saw the adjusters.... 2012 TDV8 Vogue (L322) |
Good point JayGee
