![]() | Home > Maintenance & Mods (L322) > under bonnet suspected fuel leak and info re filter replace |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3862 ![]() ![]() ![]() |
You can do it in situ, but the job is much easier if you take out the N.S. air filter box first. (5 minutes max) extra work ).
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1486 ![]() ![]() |
The fuel cooler is to the left (when viewed from the driving position) of the fuel filter. It cools fuel unburned returning from the engine. I would check the cooler and all the fuel hoses - they're all the quick release type so I would also check they're all firmly clicked in place.
Old-un Member Since: 12 Feb 2022 Location: Manchester Posts: 152 ![]() ![]() ![]() |
Gary, thanks for your very helpful info I will check everything you suggest after removing the air box.
The water seaparator unscrews from the bottom and has a little O ring on. It may be damaged or faulty or not tight enough. If you need a new one, they're easy to get.
Finally found time between domestic chores to replace the fuel filter, Mahle as suggested ,£40 Ebay.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8741 ![]() ![]() ![]() |
Glad it's sorted |
kokamagi Member Since: 31 May 2020 Location: Viljandi Posts: 84 ![]() ![]() ![]() |
Can you please share a link to water separator? Can't say they're so easy to get. Everywhere I've asked they say it only comes with the whole fuel filter assembly that costs between 400 and 500 euros. That is ridiculous price for just a little thingy. |
It can't be triggering water release by itself, since it's not an actuator, just a 1-wire sensor. Only thing it is triggering is the message on the display, so you can release it by hand. ![]() When it leaks through drain port, it is not sealed properly, when it leaks through the wire connection, it means the plastic core is broken and not hermetic anymore. I have the latter problem, so need a new separator, which is a real pain to find. ![]() |
It's not a separator, it's a sensor - the separation is done by physics and the design of the filter.
Yep, at the moment I just put the plastic screw and seal, that came with new filter, on and left the sensor attached to the wire and fixed somewhere with cable ties. At least it doesn't leak and no fault codes either. Not gonna pay stupid amount for it. Pretty useless thing anyway. |
Would it be worth you having a browse around a breakers yard with a spanner in your pocket? |
