Home > Maintenance & Mods (L405) > Restricted Performance
supershuttle
When I do a search there’s lots of stuff on restricted performance (to much?). I’ve had the red triangle when giving it plenty but also when just reversing off the drive. In every case I stop give it a minute then continue on my way driving as normal. I would appreciate any thoughts as it’s only done it a few times but it’s disconcerting. Geoff
Post #640735 24th Aug 2022 2:05pm
Baltic Blue
Time to get your iid out Geoff and read the fault logs.
Too many possible causes to guess.
Cheers
Post #640737 24th Aug 2022 2:17pm
supershuttle
Thanks Mike,
But sadly no faults to be seen. Geoff
Post #640743 24th Aug 2022 3:07pm
colalowe
United Kingdom 2012 Range Rover Autobiography TDV8 Buckingham Blue
When I had the intermittent faults I had the IID tool connected and when the red triangle appeared I searched the faults but selected Advanced mode and selected something like 'faults this cycle' or 'faults since last clear'
I cant remember the wording exactly now but doing this showed the fault causing the intermittent fault.
Worth a try if you haven't already. 2012 TDV8 Autobiography Baltic Blue
Previous
2007 BMW M5 E60
Post #640747 24th Aug 2022 4:25pm
supershuttle
I’ll be giving that a try, thanks Geoff
Post #640820 25th Aug 2022 9:01am
