![]() | Home > Technical (L405) > This from the rear |
| Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1901
…………. V6 Vogue - “Less is More” - less to go wrong! |
| SVAuto_Man Member Since: 16 Aug 2022 Location: Coventry, UK Posts: 110
I thought that but struggling to recreate it. Is there a way I can replicate it? |
| Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631
If you can't replicate it reliably, how do you expect the dealer to? |
Yeah exactly. That’s why I am looking for ideas of what it could be to see if I can replicate if it’s a certain fault. Like if it’s fuel slap, what is the best way to replicate the fault |
Well firstly, not everything is a 'fault', sometimes vehicles have certain characteristics in the right (or wrong) circumstances - you also need to be careful of confirmation bias, that is, you or the internet have decided what the cause of the concern is and set about to prove it... down entirely the wrong rabbit hole.
Hi ya,
| CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1431
If the car going up the hill involves a downshift, and/or extra acceleration on your part, it might need the gear change software update. Search for threads on that. The issue is that the gear does not come in quickly enough and when it does, the revs are higher and it sends a thud down the driveline. Mine had this and the software update cured it. Note the update is not something done on normal services, it is only for cars that thud on kickdown. There is, I think, a 'service bulletin' on the topic to which you could refer your dealer.
Hi ya, will try a kickdown down tomorrow, that’s an easy thing to try but good shout |
Lol at todays prices, not that simple lol but yeah if that would test it out |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35883
could be this,
Yeah the fuel slap issue. Sounds a very good shout. Will see if I can cause the sound tomorrow and Sunday. Will then fuel up to the brim and try again |
| James W Member Since: 29 Nov 2009 Location: Riyadh Posts: 303
Well you live and learn. Mine does this very occasionally as I drive away from the end of my driveway or at roundabouts. I thought it was something loose in the boot |
