Home > Technical (L322) > Tdv8 3.6 stalls when in gear
William97841
So basically on a road trip on been fine other than got a knocking noise when pulling away but this is the problem. Started the car all ok let it sit for 30secs foot on brake put it into reverse let the foot up and it stalls???? So switch it off then on done it again…then started it up left it for 1 min driving like normal?? No codes either help!!
Post #640940 26th Aug 2022 10:29am
garyRR
Could be a number of things currently:
- torque converter not engaging
- gearbox badly overdue an oil change
- seized turbo(s)
- EGR fault
An automatic stalling is normally caused by air/fuel mixture issues or the automatic box so, these are what I'd start looking at.
But, I would start by removing the intake and inspecting the EGRs, as these have been known to cause stalling at idle on the 3.6 TDV8.
Do you ever get any shudder at low speeds? This would indicate torque converter. 2015 Range Rover Autobiography 4.4 SDV8
Post #640975 26th Aug 2022 3:39pm
William97841
Thanks Gary for the reply turbos are good I believe as I told they was replaced before buying but not 100% sure. Well about the shudder I am getting a vibration but not only at low speeds does it all the way up to 65mph so think that could be the propshaft. Could be wrong. I reckon your right about the egrs got a feeling it’s them I’ve had nothing done to them and originals I believe and at 141k would not be surprised. Although got a hard downshift from third to second could that be the torque converter?
Post #640992 26th Aug 2022 7:17pm
garyRR
The 3.6 is known for the torque converter needing replacement also.
It may be one of these issues to be a process of elimination. Maybe start with checking the EGRs for leaks and an oil and filter change on the transmission with a tube of Dr Tranny. 2015 Range Rover Autobiography 4.4 SDV8
Post #640997 26th Aug 2022 7:58pm
