Home > Technical (L322) > Auto mirror fold?
tymh
United Kingdom 2008 Range Rover Vogue TDV8 Tonga Green
Auto mirror fold?
Is is possible, using the IID tool, to set the the mirrors to automatically fold in and out when locking and unlocking? Tym
(current) L322 3.6 TDV8 Vogue 2008 Tonga Green
(previous) L322 4.4 LPG Vogue SE 2003
If it sticks, force it. If it breaks, it needs replacing anyway.
Post #641598 31st Aug 2022 11:13pm
Yes... Thumbs Up Pete
-Click here for Thread-
Post #641602 31st Aug 2022 11:29pm
dhallworth
Can this be done on the earlier 322’s as well, Pete?
I know the 2010 onwards cars do it but wasn’t aware you could program the earlier ones to do it too.
I’d like to program the 2 stage unlocking too.
Post #641606 1st Sep 2022 12:05am
Phoenix
I've done it, but not by programming as the support isn't there in the hardware. Essentially by using a relay across the mirror switch contacts triggered by the lock/unlock signal with an 'aux on' inhibit and a simple timer circuit to trigger a relay across the unlock switch on the centre dash triggered by 'ignition off'.
Two stage unlocking is easily programmed, as is the 'chirp on lock', can be done per key. - I don't use IID so not sure of the process with that tool.
Post #641614 1st Sep 2022 7:21am
tymh
Thanks Haylands… any clues as to where I find it?! 🤣 Tym
Post #641618 1st Sep 2022 7:59am
