Home > Maintenance & Mods (L322) > Whistling from heater blower?
Danwilderspin
My heater blower has started whistling and Hager’s worse and more annoying the faster it goes…
Any ideas if this is common or where to start?
Cheers Current stable:
2015 5.0 V8 S/C AB
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #642525 9th Sep 2022 5:29pm
tj196443
United Kingdom 2010 Range Rover Vogue TDV8 Zermatt Silver
Mine sometimes does that every so often, usually I just turn up the blower speed and then back down again and it’s stops.
Post #642884 13th Sep 2022 8:31pm
DrRob
Ditto. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #642887 13th Sep 2022 8:49pm
btiratsoo
United Kingdom 2009 Range Rover Vogue TDV8 Buckingham Blue
Hello Dan
Mine has been doing that. I used to just increase the speed and then slow it down again, usually enough to shut it up. I have since changed the final stage resistor as it stopped working one day. Its been silent ever since.
On a side note, I have a feeling its just coincidental in my case and it may well be leading to replacing the blower unit bearings, a big job by all accounts although there are some work arounds on here and YouTube.
Ben Current vehicles:
1944 Fordson Standard
1982 Land Rover Series 3 88" petrol
1984 Ford 4610
2009 3.6 TDV8 Vogue
2017 CLS Shooting Brake
Post #642889 13th Sep 2022 9:05pm
