![]() | Home > Technical (L322) > What is this & what does it do? |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1486 ![]() ![]() |
It's the exhaust gas recirculation valve. The two coolant hoses are feed and return to cool the exhaust gases. Below, the exhaust gases pass through.
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 570 ![]() ![]() ![]() |
Thanks Gary, Blowed if I could find what it was. |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3264 ![]() ![]() ![]() |
Thanks for pointing this out Gary. I didn't think Petrol engines had EGRs but now know |
That's exactly what I thought so I had to look it up to confirm as well because I was doubting myself. But Microcat lists it for the 4.4 AJ V8 and the picture of the part matches the engine photo so, clearly it does. 2015 Range Rover Autobiography 4.4 SDV8 |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
It's not actually further combustion, exhaust gases are pretty inert and wont burn, operating EGR reduces your cylider capacity, lowers temperatures etc. Techincal explanation: Within modern internal combustion engines, Exhaust Gas Recirculation (EGR) is a method to control Nitrogen Oxides (NOx) emissions, produced as a by-product during the combustion process. Air from the environment, mostly a combination of Oxygen and Nitrogen, combines with fuel and ignites inside the combustion chamber, temperatures increase and produce NOx emissions. The EGR system works by returning a small portion of exhaust gas to the engine's combustion chambers through the intake manifold, lowering combustion temperatures and therefore reducing the amount of NOx emitted. The EGR valve is the main component of the EGR system and it's normally closed. It connects the exhaust manifold to the intake manifold and is controlled by either a vacuum or a built-in electric step motor. The function of the EGR valve is to control the flow of exhaust gas being recirculated depending on the engine load. Nitrogen Oxide (NOx) Nitrogen oxides are emissions produced as a by-product from the process of combustion, Nitrogen and Oxygen gases in the air react during combustion, especially at high temperatures. NOx is a major component of smog and can have detrimental affects on human health as well as well as ecosystems and agricultural crops. Therefore, incorporating EGR systems into the design of a car is important with regards to lowering harmful emissions to save the environment and have a positive impact on human health. BMW i3 Electric Car 2012 Full Fat RR 4.4 TDV8 (now gone) 2006 VW Touareg 3.0 TDi V6 |
