Home > Technical (L322) > 2011 vogue drivers seat movement stopped working
Richycsurfer
United Kingdom 2004 Range Rover Vogue Td6 Bonatti Grey
As above really, my drivers seat has stopped moving in any direction yet the lumbar and heated seat still work. Is there a fuse which covers just the motors?
Post #642696 11th Sep 2022 6:18pm
Googs
Australia
I have the same problem on my 02-03 L322....does the tilt on steering column still work?
I've purchased a S/H seat switch controller as i have worked out the electronics go bad in the seat controls after a while.
The Lumbar is on different circuit to the forward and up-down and memory controls. 2003 RR L322 4.4 ltr Auto Zambezi silver Custom paint
Post #642706 11th Sep 2022 7:50pm
Richycsurfer
The steering wheel movement fortunately does work!
Post #642711 11th Sep 2022 8:37pm
Richycsurfer
Any more ideas or suggestions on tests I can do? When I bought the car the movement took a minute to spring into life.
Post #642910 14th Sep 2022 7:12am
garyRR
They have separate fuses for the motors in the front fuse box.
Take these out and check them first.
Then I'd have a look under the seat and make sure the multiplug hasn't come loose.
Then I'd unscrew and unclip the switch panel and check there isn't any damage to the mutiplugs into the switches. 2015 Range Rover Autobiography 4.4 SDV8
Post #643007 15th Sep 2022 9:08am
Richycsurfer
Thanks for the reply - fuses were intact and powered so after removing the side panel it was found that the smaller white multiplug had become loose. Seat now operating as intended!
Post #643012 15th Sep 2022 9:57am
Thumbs Up We like free fixes.... Pete
-Click here for Thread-
Post #643028 15th Sep 2022 1:08pm
double post... Pete
Post #643029 15th Sep 2022 1:09pm
