Home > Technical (L322) > Double glazing?
jk3528
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Zambezi Silver
Double glazing?
Did they ever put double glazing in a rangerover there’s a guy at work says his 08 has it
Post #643330 19th Sep 2022 2:28pm
People call it double glazing, it's actually laminated glass in the side windows. but you can see the two panes either side of the plastic central part if you look at the edge of the open window. That's why it gets the "nickname" double glazing...!! Pete
-Click here for Thread-
Post #643334 19th Sep 2022 2:34pm
mjdronfield
They are double laminated, so tends to get called double glazed, 2 layers of glass with a laminate between them, On the side front windows. Optionally on the rear too.
But not like on the older 7 series BM’s for example, that seemed to have a proper air gap inbetween them.
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #643336 19th Sep 2022 2:40pm
garyRR
I'm pretty sure it was an option on 2006-2010 cars, but very rare.
From 2010 onwards, I think the Westminster and Vogue SE (later replaced by Autobiography) had the noise insulated front screen and "double glazed" side windows in the front and rear. Having had a 2006 without and my 2011 with, I can tell you the noise difference is very noticeable and is one of the reasons i think the jump is worth it!
There was a period through the 90s and early 2000s when premium luxury cars like the 7 series, Phaeton, S Class etc all had double glazing resembling what you'd recognise as double glazing, being 2 panes of glass with a sealed gap filled with noble gas on the inside.
You will find most vehicles with "double glazing" these days are double laminated glass, where two panes of thinner glass are sandwiched together with a laminate in-between. When you wind the window down, you can see the seam of the two panes. It saves weight and space (and no doubt cost also) but delivers almost as good performance as vehicular double glazing, so delivers a nice middle ground. Some ultimate luxury cars like the S Class and Rolls Royce are still available with it but it's perfectly ok to call double laminated glass double glazing because, it is a form of double glazing.
The L405 and L494 Range Rovers all have it as standard, as does the 2021-> Tesla Model 3. 2015 Range Rover Autobiography 4.4 SDV8
Post #643346 19th Sep 2022 4:31pm
Some 2023 models are getting triple layered glass... Thumbs Up
Post #643347 19th Sep 2022 4:42pm
