![]() | Home > Maintenance & Mods (L322) > Timer for climatization: it is a possible upgrade? |
Eddy Member Since: 03 Mar 2022 Location: Italia Posts: 26 ![]() ![]() ![]() |
Dimenticavo: Vogue l322 tdv8 4.4.
S60R Member Since: 23 Mar 2022 Location: West Sussex Posts: 50 ![]() ![]() |
Hi Eddy,
Ottimo!!!
Optimal!!!
Perfecto Eddy!!
L322 , year 2012
I couldn't resist ... I activated the parking heater menus from gap and voilà programmable ventilation appeared on the screen! Fantastic!!!
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1493 ![]() ![]() |
The Webasto also cycles the engine coolant when temperatures are near 0C or below.
Great eddy …. Glad it worked.
Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 307 ![]() ![]() ![]() |
If there are the right modules already in the car, as there are in the MY2010 and up, there is also the option to buy a key fob. I’ve just been through a lot of faffing about to get the correct combination of module and fob. Thankfully it now all works perfectly ( and just in time for winter ). I may post a thread on what I found worked if that doesn’t duplicate any current threads on here. In the mean time here’s the link mentioned by GaryRR; https://motor-roam.co.uk/l322-range-rover-...-10-pounds Note; if you do this I’d suggest using better quality crimped connectors and professional quality crimping tools. TDV8 4.4 2012 |
Heatshrink solder connectors are the one! Waterproof, glue to the sheaths and zero chance of disconnection. 2015 Range Rover Autobiography 4.4 SDV8 |
