Home > Maintenance & Mods (L322) > Appearance Cover washer
lschwarcz
United States 2009 Range Rover Autobiography 4.2 SC V8 Bournville
Hi Everyone,
I needed to remove the engine cover on my 2009 Autobiography and discovered that there should be a washer between the top of the "Engine Cover Mount Stud (part # KKN500061) and the bottom side of the engine cover.
From what I can see the cover has a grommet in the mounting hole and this washer is held in place by the cylindrical part sticking up (sorry about the poor description).
Here are a bunch of photos of this small washer.
I've been unable to find it in any parts diagrams and one mail order place I called tells me it's only available with the whole appearance cover ($320 USD).
It seems that I could easily use an ordinary flat washer. But, I'm just too pedantic for that and really want to get the correct part Confused .
Has anyone seen this available anywhere or maybe suggestions on where I could look for it?
Thanks!
Larry. 2009 Range Rover L322 Autobiography
Bournville/Ivory
Save lives, give blood.
Post #644162 27th Sep 2022 11:31pm
garyRR
Have you considered a disc spring nut or a large flanged nut, which would get very close? 2015 Range Rover Autobiography 4.4 SDV8
Post #644175 28th Sep 2022 9:20am
Weegie
A top hat washer of the right size might do what you want John
GAP iiD BT-Sold
Post #644179 28th Sep 2022 10:25am
oggy
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Java Black
i had the same thing and i used top hat fixings that i think are used from the grill from a discovery 2 front grill ? i am trying to find a picture of them for you they worked a treat when i do i will put a picture up
 new vehicle purchase
2007 supercharged 4.2 java black .sand leather vogue se trim
previous cars .
range rover classic 200 tdi
discovery 1 200 tdi
freelander 2 2008 hse
discovery 1 300 tdi
p38 4.0 ltr man r380 ex royal support vehicle on v5c
discovery td5 man off roader
Post #644185 28th Sep 2022 12:46pm
lschwarcz
Re: Appearance Cover washer SOLVED
Hi Everyone,
I found the answer! It turns out that this washer slid into a rubber grommet in the appearance cover. I just happened to stumble upon a, “M6 Rubber Grommets Bolt” on Amazon and it’s the actual grommet with the top hat washer. I guess in this application it’s called a, “Grommet Bolt.”
The new one is a bit thicker but works perfectly. Original is on the left in this picture.
This is the actual one I bought (pack of 10) for only $11 USD.
https://www.amazon.com/dp/B0B6N6Z1JG
I’d bet if you walked into almost any motorcycle shop and asked for this they’d likely have them to mount fairings onto the bikes. Maybe not as cheap but you’d get them right then!
Thanks again to everyone!
Bournville/Ivory
Post #671176 14th Aug 2023 5:03pm
