Home > Technical (L322) > Fault code
J evro
England 2008 Range Rover Vogue SE TDV8 Stornoway Grey
Fault code
Hi all,
Recently left the lights on and battery became low and on starting threw up “Engine management light” and a load of faults, took to have a diagnostic check and had all but 2 codes checked/removed,
P138F-21 - Turbocharger boost control position sensor B minimum/ maximum stop performance. (intermittent)
P132E-22 - Turbocharger/Supercharger boost control B performance, (intermittent),
EML cleared but has re- appeared and engine feels “lack lustre”
Sounds frightening to me with little knowledge and the garage I took it to are now on holidays
Any advice / help appreciated , I’ve had a search but not a lot came up for me
Thanks in advance
John
Post #644315 29th Sep 2022 4:18pm
Googs
Australia
Before you do anything you need good battery voltage....low battery voltage will produce all sort of gremlins Shocked 2003 RR L322 4.4 ltr Auto Zambezi silver Custom paint
Post #644441 30th Sep 2022 7:15pm
Phoenix
Looks like the turbo has lost it's end-stop position recognition due to low voltage on cranking.
Try this:-
Charge the battery overnight
Disconnect the battery -ve (making sure the keys are out of the vehicle and all the doors are closed and have been for >10mins)
Leave well alone for ~30mins
Reconnect the battery -ve in a 'definite movement' so as to prevent or minimise any contact arcing.
Turn on the ignition, let everything stabilise for 10-15 seconds, then start the engine.
Turn off, clear DTC's then test drive.
I doubt there's any hardware fault, it's possible you might need the turbo position to be calibrated but a battery disconnect / reconnect will usually clear things down.
Post #644443 30th Sep 2022 7:24pm
J evro
Thanks gents, will try when home 👍
Post #644483 1st Oct 2022 2:42pm
J evro
Fault found and cured,
FYI if anyone else finds themselves in same situation,
Found O/S Turbo actuator seized, freed up (both sides) Cleared EML light and running sweet again (Phew had a little panick there )
Post #644931 6th Oct 2022 5:00pm
