Home > Technical (L322) > 4.4TDV8 "CNG" conversion - thoughts?
GGDR
Saw this Westminster 4.4TDV8 with a "CNG" conversion
So many questions in my mind;
-Is CNG different to LPG
-Didn't know diesels could be converted
-Is if for sale because it's problematic
https://www.pistonheads.com/buy/listing/13...d%20search
. Cheers, Greg
Post #644360 30th Sep 2022 7:04am
GGDR
Obvs straight on fullfatrr then google
First question to myself Google says:
CNG and LPG fuel also have both similarities and differences. While CNG is comprised of methane, LPG is comprised of propane and butane. CNG is typically used as a substitute for gasoline in automobiles, while LPG is often used in the industrial, refrigeration, agricultural and catering industries.30 Jan 2020
CNG vs. LPG vs. LNG Fuel: Understanding the Differences | UTI
 Cheers, Greg
Post #644361 30th Sep 2022 7:06am
GGDR
Next:
CNG filling stations in United Kingdom in September 2022
https://www.glpautogas.info/en/cng-stations-united-kingdom.html
 Cheers, Greg
Post #644363 30th Sep 2022 7:10am
jimmie
Poland 2004 Range Rover Vogue 4.4 V8 Epsom Green
CNG and LPG are very different fuels. LPG has low methane number which means it is easy to occur preignition / knock combustion. with high compression turbocharged, high efficiency engine is quite difficult to control afr with lpg in compare to cng.
Of course you can find both solutions on diesel engines. Converion diesel to diesle+gas has only sense with long stable motorway trips because the way how it works.
Post #644470 1st Oct 2022 10:11am
jimmie
Post #644471 1st Oct 2022 10:11am
AJGalaxy2012
Gas conversion of diesel engines offers some advantages, generally a 25% increase in torque!
How does it ignite? that puzzled me for a while, the solution is simple. The diesel injection pump injects a small amount of diesel (typically idle), the diesel ignited by the compression fires the gas be it LPG or CNG. BMW i3 Electric Car
2006 VW Touareg 3.0 TDi V6
Post #644472 1st Oct 2022 10:21am
dingg1
13 filling stations in the UK says it all really Shocked
Post #644477 1st Oct 2022 11:53am
