Home > Maintenance & Mods (L405) > L405 Oil Cooler Coolant Leak |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 2664 |
Oil leaking from the oil cooler is a common issue on these engines - almost inevitable and plenty of info on it if you use the search engine . If it's leaking coolant it may be the EGR cooler below it - pray it isn't as it's a much more expensive and complicated job. 2012 TDV8 Vogue (L322) |
5th Feb 2023 7:34pm |
Tuckmeister Member Since: 16 Jan 2022 Location: Oxfordshire Posts: 7 |
Hi JayGee
6th Feb 2023 7:42pm |
It may be the EGR cooler under the oil cooler then - unfortunately this is a much more difficult job. 2012 TDV8 Vogue (L322) |
12th Feb 2023 11:12am |
what sort of costs involved ?? Labour i presume most expensive.. How big off a job ??
12th Feb 2023 5:51pm |
Get a proper diagnosis before you go any further. A garage with a borescope should be able to see where the coolant is coming from. I also suggest a specialist LR garage rather than a general garage. 2012 TDV8 Vogue (L322) |
13th Feb 2023 10:04am |
Huwrhys Member Since: 07 Feb 2018 Location: Hornchurch Posts: 548 |
I had the same diagnosis from a main dealer but it turned out to be the thermostat housing. It’s a three hour job once they have the parts. Housing is £125ish and labour approximately £400.
6th Mar 2023 8:45am |
Marcel M6 Member Since: 15 Jun 2021 Location: Hertfordshire Posts: 19 |
'Once they have the parts' seems to be an issue at the monet. have same problem on mine. I've been told upper and lower thermostat housings/pipes etc are out of stock until May!
6th Mar 2023 2:30pm |
