Home > Maintenance & Mods (L322) > Deployable Side Steps fitted… roof button goes where?
Ffrr-lover
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Evening All!
So, I’ve just joined the Deployable Sidesteps club! Got a fantastic FaceBook deal on a set which has snapped rear brackets, but have had them welded and they seem to work fantastically! Nice and smooth and no issues with their speed.
I need to fix my side skirts (and some rust) before I upload any pictures…
However, the issue I have… is that the roof button doesnt fit!
The instructions show the button screwing into that section of the roof console, however my car simply had a vent. I’ve removed it, but have no options to fit my button.
Is there a simple part i can order to allow me to fit my button? Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2014 Audi Q7 3.0d (good riddance)
2010 L322 Autobiography 5.0 Supercharged
2011 L320 HSE 3.0 sdv6
2014 Jaguar XF-RS 5.0 supercharged
2007 BMW 535D
2005 Mini Cooper S
https://www.fullfatrr.com/forum/topic59478.html
Post #645825 17th Oct 2022 8:36pm
Ffrr-lover
This is the part in the roof console that was taken out… clearly not designed to hold a button…
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #645827 17th Oct 2022 8:39pm
mjdronfield
No direct help, but what you have taken out is where the microphone goes for the phone/voice control.
Can’t see a pic of a switch fitted… sure I’ve seen some somewhere.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #645828 17th Oct 2022 8:54pm
Ffrr-lover
Now that is what i assumed before taking the console down… it turns out my microphone is behind one of those central “vents” to the left of the button in my picture… with the other being empty.
I dont have a picture of the rear, but the microphone is a circular device.
Not sure if there are differences based on age? My car is registered in 2011, but reports as an MY12… Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #645829 17th Oct 2022 9:02pm
mjdronfield
Just looked on autotrader and searched for the word deployable.
Looks like it is fitted in that position, as you say, must have moved the mic from when I had my TD6 then.
I can see a pic of one with the switch here…
Maybe you can mod the vent one, but looks like there might be a new outer section used….
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #645831 17th Oct 2022 9:07pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
When you buy the kit you get the surround that fits into.
Post #645834 17th Oct 2022 9:34pm
Tinman
https://www.fullfatrr.com/gallery/albums/u...ment~2.pdf
fig 33
Post #645835 17th Oct 2022 9:37pm
Ffrr-lover
That would be why then… I purchased bits separately.
I’ll check the bay of E for the part… unless anyone knows where to buy one from? Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #645837 17th Oct 2022 10:16pm
Barmybrummie
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
Ah sorry ffrr-lover I did forget to mention that there is a black surround for the button to clip into. It just screws into place where the other black vent type thingy is in the roof panel. I might be wrong but I seen craddock 4x4 selling parts for deployable steps, you could give them a try. And good to see they are working spot on. You having better luck than me lol.
Post #645909 18th Oct 2022 9:04pm
Barmybrummie
Post #645910 18th Oct 2022 9:16pm
dhallworth
I enquired about that bit before when I started trying to piece together a kit from bits I’d found but it wasn’t available separately from the kit unfortunately.
Your best bet would be to find a breaker where the seller will sell it.
Post #645913 18th Oct 2022 9:40pm
jimmie
Poland 2004 Range Rover Vogue 4.4 V8 Epsom Green
i cut carefully this black microphone plate to fit button inside. fits perfectly. Just need to do it really carefully because after cuting hole there will be about 2mm of plastic on the sides.
Post #645917 18th Oct 2022 9:55pm
Ffrr-lover
Ah, it can be dine! When i eyed it up it looked like the button was too wide!
I’ll have a look at doing the same… while looking at breakers, Craddock 4x4, etc, in case they have something. Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #645973 19th Oct 2022 6:26pm
Ffrr-lover
Cheers for helping me out on this Thumbs Up
I’m really happy with them… although they are coming off again at the weekend (hopefully) to treat the rust I found!
I’ll also take a look at cleaning them up and greasing them too. They work well, but no harm in doing so. Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #645974 19th Oct 2022 6:29pm
Ffrr-lover
One carefully “adjusted” plate now fitted with the button! Not the tidiest of jobs… but better than a hanging button! It’ll do until I find the proper parts Thumbs Up Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #646424 24th Oct 2022 8:15pm
