![]() | Home > Technical (L322) > L322 3.6 tdv8 EGR and Injector |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3304 ![]() ![]() ![]() |
EGR disintegration can take out the turbo and worse if bits get ingested into the engine. It's a particular weakness with these engines unfortunately. 2012 TDV8 Vogue (L322) |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1486 ![]() ![]() |
From the fault codes, they sort of suggest several underlying issues.
martinL322 Member Since: 19 Oct 2022 Location: Zürich Posts: 4 ![]() ![]() ![]() |
Thanks guys! Much appreciated! I will see if I can get a reasonable diagnosis and keep you posted |
Quick update here, currently waiting for initial repairs. Bought and refurbished both sides EGR valves and an injector (all used parts) and hope that will get the car moving again.
So in the end found a qualified and affordable mechanic to start proper diagnosis, which after initial tests resulted in the engine being taken out of the car entirely.
