Home > Technical (L322) > Engine idle - nothing happens
VMPP
Portugal 2007 Range Rover Vogue TDV8 Buckingham Blue
Hi everyone!!
Since last friday, my car has started to develop some kind of strange symptom.
Issue is:
When I start the car after it has been stopped overnight, the engine doesn't fully go to the 750-800 rpm idle speed.
Engine starts, but it stays at around 500 rpm. When that happens, everything seems dead. i can press the throttle pedal fully, move the gearbox leveller, but nothing happens. The car just seems to be semi-dead. Engine just sits there working like a generator, just going vum vum vum vum vum almost chocking...
If i restart the engine, then everything clears out and the car is back to normal.
Anyone has any idea on what I may be facing?
Post #646335 23rd Oct 2022 9:55pm
AJGalaxy2012
Suggest you say what engine and year of car for people to advise you. BMW i3 Electric Car
2006 VW Touareg 3.0 TDi V6
Post #646342 24th Oct 2022 5:08am
VMPP
Yeah.. Laughing Laughing
2007 3.6 tdv8
Post #646354 24th Oct 2022 11:35am
First thing to do is try a battery reset.... Thumbs Up Pete
-Click here for Thread-
Post #646360 24th Oct 2022 12:51pm
VMPP
That's one of the last things I want to do... as the car is with the steering lock problem active... Laughing Laughing
If I disconnect the battery, I'll have to be once again pour 3 litres of wd40 in the steering column to make it work. Always knowing that there's one day that, that solution won't work! Rolling Eyes
Post #646377 24th Oct 2022 3:25pm
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
Could that not be causing the issue?. Whistle
Post #646391 24th Oct 2022 4:34pm
