![]() | Home > Technical (L322) > L322 Rear Subframe Bush Specification |
Ajmngn Member Since: 25 May 2021 Location: Cambridgeshire Posts: 209 ![]() ![]() ![]() |
Hi all, I can see that the part numbers for the L322 rear subframe bushes are different between front and rear. Can anyone tell me the actual difference? Is it a size thing, or is it a factor of the rubber compound and compliance?
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 826 ![]() ![]() ![]() |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 1010 ![]() ![]() ![]() |
Hi Andy, let me know what you do - as I need to do the same !
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1342 ![]() ![]() ![]() |
when i looked at the parts sheet i thought it said all L322s after 2004 were the same
You're picture shows the wishbone arms bushing mate.
ok RR 2005 4.4 petrol
So...after much research and looking at pictures online, it's clear that the BMW X5 E53 bushes will fit in the L322 subframe. HOWEVER, there is a difference in the metal interface on the top of the bushings. I can see that the BMW versions are flush, and the L322 bushes have the slight protrusion, which is clearly linked to the orientation of the washer that sits between the bush and the body of the car.
The standard bushes, as in my picture, are actually riveted in place. Two rivets for each bush. |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3329 ![]() ![]() ![]() |
I’ve just done mine with the original LR bushes. They were TIGHT to get into place even when using the official LR lubricant.
Interesting that David. Wonder why they started using rivets?
Indeed.
I bought the same tool after I saw it in your previous post. Gonna grease it up well and hope for the best.
