![]() | Home > Technical (L322) > Another FBH issue!! |
tj196443 Member Since: 08 Oct 2018 Location: Newcastle Posts: 186 ![]() ![]() ![]() |
Last couple of morning the fbh has seemed to run but hasn’t really produced any heat into the cabin, noticed this morning that even though I could hear the fan in the wheel arch there was no ticking noise from the rear. I did top up the engine coolant about half a pint just before this happened and read somewhere this can cause water to get into the pump, not sure if that is so though. Going to put the IID on when I get home and see if that throws up any faults. |
jaguar3 Member Since: 25 Sep 2022 Location: Estonia Posts: 194 ![]() ![]() ![]() |
Be aware, water pump may get stuck sometime and no pumping (or pumping weak), and no error code at the same time due electric circuit is ok. FBH will start and shut down in couple minutes in this case.
TDV8 Paul Member Since: 30 Nov 2020 Location: Tadworth Posts: 224 ![]() ![]() ![]() |
They won’t produce heat until the outside temp falls to 5c and below 2009 (2010 MY) 5.0 Supercharged Autobiography
Thanks for the replies chaps and the info, it has been acting up recently to be honest. Sometimes it will work and sometimes not like this morning, I’m the past when it hasn’t worked the dash light has been flashing and you can hear the ticking from the pump bit still no heat. The outside temperature here up North was 7degrees so it probably should have kicked in, I checked with the IDD this evening and it came up with a short circuit fault but I forgot to take the details, I’ve set it on the dash timed climate for in the morning and see what happens. |
FBH worked perfectly this morning so the pump isn’t knackered |
