![]() | Home > Maintenance & Mods (L322) > Wheel alignment |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3385 ![]() ![]() ![]() |
Alignment is at standard height ( best if you can set the suspension in tight tolerance mode in workshop tool like the GAP IID) Are the camber and castor within spec? Check all the bushes and joints for wear and play. If all good and the hub won’t adjust to within spec then you have to consider bent arms or other damage. 2012 TDV8 Vogue (L322) |
Ben84 Member Since: 13 Dec 2018 Location: Cornwall Posts: 88 ![]() ![]() ![]() |
Before
Both rear rose bushes were replaced last year as well |
Camber is all good it's just that rear toe on the NS that is still the issue |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1360 ![]() ![]() ![]() |
Mines the same but on the rear right. I suspect the replacement rear toe arm is a smidge longer.
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
car should be put into "High Tolerance " to make those adjustments. 2012 Vogue 4.4 TDV8 - Current
I think you mean 'tight tolerance' - useful but not essential and the standard procedure for alignment is to change the suspension height up and then down to settle it before measurement and adjustment. 2012 TDV8 Vogue (L322) |
