![]() | Home > Technical (L322) > Differentiating collapsed lines or seized calipers? |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3342 ![]() ![]() ![]() |
Can't see how a brake line would cause this and the callipers are prone to piston seizure. 2012 TDV8 Vogue (L322) |
Flexible brake lines can cause the same symptoms as a binding brake caliper if they develop a split or pinhole on the inside surface, it's more common than you'd think.
lodelanelad Member Since: 14 Dec 2021 Location: London Posts: 62 ![]() ![]() ![]() |
Much appreciated Phoenix! |
No worries! Don't forget to purge any air that might have entered the system, get someone to pump the brake pedal a few times and hold down, then crack off the bleed nipple 'a bit' whilst they keep pressure on the brake. |
