![]() | Home > Maintenance & Mods (L322) > RANGE ROVER L322 2012 Rear Differential Plugs part number ?? |
gettingold Member Since: 03 Apr 2018 Location: Wiltshire Posts: 286 ![]() ![]() |
Try here, it may be helpful
ergobyte Member Since: 03 Apr 2022 Location: bordeaux Posts: 124 ![]() ![]() ![]() |
Yep, been there already, but "2002 to 2012" is a long stretch and the part number are again different from the ones I mentionned ...
Send Duckworths or LRparts.net an email, either will be able to tell you the correct part numbers (and sell you the parts) from your VIN. |
Red Hot one Member Since: 09 Dec 2018 Location: Herefordshire Posts: 217 ![]() ![]() ![]() |
On my 2009 3.6TDV8, standard rear diff, not the e-diff. Landrover parts.
Actually, it's reasonably easy to find out from here
Thanks Phoenix,
It appears so, clearly the drain was a different p/n but was superceded. I can find no reference to anything other than that part number for both the drain and fill plugs.
I'm off for a buying spree then !
