![]() | Home > Technical (L322) > Fan mounting bracket torque settings |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1324 ![]() ![]() ![]() |
When I did mine I think I used the torque setting of an equivalent sized bolt used elsewhere if that makes sense. |
Furnitureman Member Since: 26 Jan 2021 Location: Leicestershire Posts: 352 ![]() ![]() ![]() |
I looked up torque settings for m8 bolts got 48nm this bracket is under a lot of stress and forces due to it housing the fan 2012 Range Rover Westminster 4.4 TDV8
It's still an M8 fixing though, any more and you risk stretching the bolt or tearing threads out of the tapped hole. |
That’s what I’ve set them at, stupid thing is I spent a hour going through the WM and although it’s mentioned I can’t see any reference to the torque 2012 Range Rover Westminster 4.4 TDV8
I think that's what I set mine to and it hasn't fell off yet. |
