Home > Technical (L322) > 2012 L322 Preheater Remote
mjdronfield
I know this is not the same year, but food for thought…
https://www.fullfatrr.com/forum/topic22993...t=retrofit
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #650934 16th Dec 2022 8:12pm
Ansi
Switzerland 2010 Range Rover Autobiography 5.0 SC V8 Adriatic Blue
TorontoDee wrote:
I have a 2012 L322 Supercharged petrol LH Drive/North American model - is there a remote start option for these, or am I better off going through the aftermarket?
Unfortunately, European cars do not have the option of remote start, that's a north America only thing. In most European countries it's unlawful to start your car with a remote control. Big Cry
Post #650938 16th Dec 2022 9:02pm
TorontoDee
Canada 2012 Range Rover Westminster 5.0 SC V8 Santorini Black
I'll take a look at a local installer that offers Viper.
Thanks Smile 2012 Supercharged L322
Post #650940 16th Dec 2022 9:25pm
JonnyCJ
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Sumatra Black
Bumping this thread as its topical and should be of use for context.
Post #724638 16th Sep 2025 6:04pm
Dutchgit
Germany 2008 Range Rover Vogue TDV8 Stornoway Grey
Yep, I installed a receiver and got a remote out the German small ads site and it works wonderful.
The only thing is that it doesn't get roasting inside as there's valve block missing in mine that blocks off coolant to the engine so the inside warms up quicker/better.
Not much of a problem with clear windows, heated seats and steering wheel. Mr. Green
Post #724647 16th Sep 2025 8:04pm
Daniel O Donnell
Ooh, you have just reminded me, I have one of these and the remote is lost as well.
I need to look into getting a replacement remote and see if I can get it to work.
Do these draw much power once they start up? Anybody know?
Post #724652 16th Sep 2025 10:52pm
Dutchgit
I seem to remember they draw a few amps at start up because of the glow cycle but not much else.
Not sure if it does in this application but I think it shuts off if the voltage in the battery gets too low.
Post #724667 17th Sep 2025 9:43am
JonnyCJ
Look at the eBay thread re a cheap brand new solution
Post #724672 17th Sep 2025 11:48am
JonnyCJ
Having trouble pairing my remote. Thought I had it paired however it had been too warm to use the pre-heater. Tried it this morning and no joy. Had a play this evening and can report as follows;
I can get the heater to come on by jumping across the live and switched live feeds to/from the receiver, so I know the heater works.
Following the procedure for pairing the remote (remove receiver power for 10s, put power back, press remote “off” button after 2s) I get a flashing red light on the remote.
The remote is a new T91R remote, the receiver is a T91R.
Could it be the remote needs a new battery ?
Anyone managed to pair their eBay Peugeot T91R successfully and operate their heater ?
Going to order a new battery and see if that works.
Post #724945 22nd Sep 2025 7:39pm
