![]() | Home > Maintenance & Mods (L405) > Oops - Water in dynamic response system…open to suggestion |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1832 ![]() ![]() ![]() |
Oh sh*t!
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1531 ![]() ![]() |
I know, and that's some of my fear, the steering rack has a water sensitive plug in it which if it senses water will open up to release water. According the workshop manual, if it pops, its a whole new rack required. ( why not have a bleed screw is beyond me, but never mind ) ... although in thinking about it, it looks like you'd be able to tap a plug into the hole that opens and seal the thing again.
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 782 ![]() ![]() ![]() |
Dynamic Response Fluid is Cold Climate Power Steering Fluid. It was developed by Texaco and is a petroleum based product (about 65%) with the rest of the makeup consisting of various polymers.
Thanks Kev. I’m totally for trying to flush it through by opening up the bleed nipples at each section and running through till clear, but I believe the valve block onwards is a secondary system which defaults to closed valves and in order to bleed I need hold them open so that new fluid from the reservoir would reach the actuators… either by diagnostics or what I’ve seen in the workshop manual is a specific tool which plugs into the valve block to open it.
A full fluid change isn't easy to do, you really want to do it component by component and used compressed air to blow any remnants out. If it went into a dealer, LR process would be the same as for contaminated fuel system - change the lot.
Thanks Phoenix Reality is I’m not likely to sell it. It was the only one of its style I saw and was better than many i looked at. Living in the west of Scotland with the salted roads, there has always been plenty that rusts on my land rovers over the years. If it doesn’t corrode from the inside … its likely to corrode from the outside instead !
I've only ever used SDD for that task and I don't own the IID.
Yup changing the reservoir is on the list, and i wondered whether it was filtering any of the emulsion. I could also use the old cap to make the bottle thing which pressurises the reservoir to bleed the system. ( cause there is no way I’m paying the hundreds of pounds for a genuine LR adapted pressurised ez-bleed bottle ).
I used to be, work for a different 'premium brand' these days...
That was my plan for a tool. Thanks. V8 or else ... |
