Home > Technical (L322) > Late (2012 Westminster) L322 LCM Location??
GrazzerD
United Kingdom 2012 Range Rover Westminster TDV8 Santorini Black
Am I going mad? I can’t find anywhere online that can tell me the location of the Lighting control module for my car. I have removed the panel around the bonnet pull but instead of 3 plugs going into a module there are 3 harness connectors that link harnesses. From here the cables go up behind dash and down under floor…
Really don’t want to start stripping out dash if it is actually under drivers’ seat or in boot.
Thanks in advance and sorry if this has been covered. I did search first.
Post #650239 9th Dec 2022 10:29am
V8 Bob
It is normally behind the trim on the drivers side A post pillar ie next to your legs. If you search fir the three letters LCM there are several posts on the subject including a couple of fixes and a firm that can repair them for circa £80 if at fault. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #650244 9th Dec 2022 10:45am
GrazzerD
Thanks V8 Bob. I have indeed seached and yes A pilar is where I am at... I have actually just had a callback from LR and he thinks they stopped fitting them to the cars after 2009 but is going to check for me and took my reg. This could explain why I cant find it in this possition. I will keep you all posted.
Post #650250 9th Dec 2022 11:12am
GrazzerD
So apparently it is hard wired to the door control module and then off to the BCM from there.
Post #650251 9th Dec 2022 11:15am
Paul TVR
United Kingdom 2005 Range Rover Vogue 4.4 V8 Alveston Red
Fancy seeing you here! So you're indicator is wired to the door lock, that's why it doesn't work!
Post #650288 9th Dec 2022 3:02pm
