Home > Technical (L322) > DPF full, look at the Manual
ultron
Germany 2008 Range Rover Vogue TDV8 Java Black
Following problem with my car, Range Rover 2008 TDV8
Error code in PCM ... P2459 ff
I drove the Motorway for 20 minutes, but nothing happened.
Next try, Motorway and start the Dynamic Regeneration (Gap-Tool), unfortunately the speed always remains at zero, and remains red .... So the regeneration is not started ....
Any ideas?
Where does the OBD get the speed signal from?
thx sebastian
https://www.fullfatrr.com/gallery/albums/u...G_2032.PNG
https://www.fullfatrr.com/gallery/albums/u...G_2031.PNG
Post #650881 16th Dec 2022 10:43am
ultron
Hello,
has done ... the guys from GAP Tools helped me ...
had to update the tool twice and then the Dynamic Regeneration worked ...
Post #651882 29th Dec 2022 10:48am
good news Thumbs Up ... - .- -.
Post #651885 29th Dec 2022 11:06am
Range Rover L322
Great that you've fixed it but I thought DPF was only fitted to Range Rovers from 2009!
Moving forward. If your DPF has become full or not regenned I suggest watching it closely for a while. Regens should start around 19.7g - full chart below for L322 2010-2012 - should be similar for yours.
The DPF is the receptacle or symptom for another issue and is rarely the cause of the problem itself.
19.7g Demands Regen
23.3g Amber Warning On
27.5g Red Warning On
17.46g Amber Warning Off
21.25g Red Warning Off
28.5g Maxiumum soot level accumulation before regen is inhibited
31.5g Soot level accumulation in DPF Filter is stopped
Good luck 2012 L322 4.4 TDV8 AB low mileage - a peach
1986 V8 Defender 90 County ex-Swiss Army - Red everything....
My preferred Independent: Roy Hardy. R & B AUTOS LTD, 20 Brook Road, Wimborne, Dorset, BH21 2BH 07500 866775‬ (Ex LR Chief Technician)
Post #651887 29th Dec 2022 11:22am
Faukstad
Norway 2012 Range Rover Autobiography TDV8 Santorini Black
Re: DPF full, look at the Manual
Welcome to the club Ultron...
Mine just had a visit to the garage, it seem's even though you've got the red light, driving it at constant speed (autobahn ohne stau) for 40-50 minutes with a warm engine cures even a splitting hangover.
Any ideas?
thx sebastian
Post #651988 29th Dec 2022 9:23pm
ultron
In the 2008 models, the DPF, in Germany, could optionally choose ... unfortunately mine has one
I had before the dynamic regeneration. 37.6g (gap-tool) and now I have 6.2g (gap-tool)
Post #651991 29th Dec 2022 9:41pm
Faukstad
That means you can also remove it, right.? Wink
Post #651992 29th Dec 2022 9:43pm
ultron
Theoretically yes ... but difficult in Germany ... you would have to leave it in the papers ... and you need official documents from Land Rover ...
As long as he works again ... I'll leave them in ...
Post #651994 29th Dec 2022 9:49pm
